Activity Forums Maxon Cinema 4D Things are getting Hairy!
  • Things are getting Hairy!
    Posted by Glenn Takakjian on October 15, 2007 at 9:16 pm
    It would seem that Hair objects are not effected by Visibility tags in there default GENERATE mode. If you change the GENERATE option to the other types like flat, triangle, square, etc. the visibility function works but the hair material looks completely different.
    Is there a way to get the hair to dissolve /fade out and still maintain its proper appearance? Thanks
    TAK
    Glenn Takakjian replied 18 years, 11 months ago 2 Members · 2 Replies
  • Brian Jones
    October 15, 2007 at 11:08 pm
    It can be done in the settings for the Hair material. Animate the Transparency channel, the trick is to bring Reflectiveness and Translucence in the Illumination tab to 0 as well or it won’t actually disappear.
  • Glenn Takakjian
    October 24, 2007 at 8:13 am
    Thanks… that did the trick.
    Sometimes I wish things were just a little easier!
