Activity › Forums › Adobe Premiere Pro › Thin black line at top when export to FLV from premiere
  • Thin black line at top when export to FLV from premiere
    Posted by Alex Ezorsky on November 3, 2009 at 9:28 pm
    Here is my situation:
    Footage: 1920×1080 square mpeg2
    Sequence: 720×480 .9
    Export: FLV scaled to 640×480 (obviously square)
    The final result, when played in flash player, has a very thin line at the top. There is no thin line when viewed in Premiere, and when I go 1 pixel up or down on the width or height in the export scale, it just makes bars on the sides thicker. The only video I have successfully exported as flash near these constraints was done via AE.
    Why is this sooo difficult with premiere? Any help?
    Jeff Brown replied 16 years, 11 months ago 3 Members · 4 Replies
  • Jeff Brown
    November 3, 2009 at 9:42 pm
    Have you tried enabling the “crop” in Media Encoder before you export?
    -jeff
  • Alex Ezorsky
    November 3, 2009 at 10:56 pm
    Thanks for the quick reply.
    I tried cropping 1 or 2 pixels off the top and now I get even thicker black lines on the top and bottom. Any other ideas?
  • Vince Becquiot
    November 4, 2009 at 1:51 am
    Try 648 instead of 640.
    Cheers,
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Jeff Brown
    November 4, 2009 at 1:57 pm
    If cropping off the top/bottom gives you thicker borders, crop off the left/right.
    -Jeff
