Activity Forums Adobe Illustrator Thick l’s and I’s problem in illustrator
  • Thick l’s and I’s problem in illustrator
    Posted by Jay Jones on October 14, 2009 at 8:30 pm
    I know some people experience thicker l’s or i’s if text is converted to outlines, but i didn’t convert my text to outline and when it came back from the printers all the l’s and i’s are noticeably thicker. It’s only a basic helvetica font as well, nothing fancy. Does anyone know how i can fix this? thanks
    Vincent Rosati replied 16 years, 8 months ago 2 Members · 1 Reply
  • Vincent Rosati
    October 15, 2009 at 4:59 am
    I’ve only seen thickened ‘i’ or ‘l’ in PDFs on screen, however I have seen all type appear heavier when outlined and printed – at least, in digital print.
    It’s possible your printer may be using a different version of the same typeface, which could definitely cause unexpected results such as this, especially if any stroke or other effects are applied to the text.
    Unless you expect your printer to make edits to your text, I’d create a text-outlined version of the file (myfile_ol.ai), and give that to your printer. It would eliminate the issue.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
