Activity Forums Adobe After Effects There’s a green object in my green screen!
  • There’s a green object in my green screen!
    Posted by Katheryn Rupert on July 23, 2013 at 7:28 pm
    I’m keying out green screen for a web series, which was cheaply shot, so the green screen is a mess to begin with. I’ve been able to use auto-trace, keylight and a couple of other tools (spill suppressor, simple choker, etc) in AE 6 to get the green out. Everything looks pretty good except that the main character is wearing, get this, a green leafy headband (think a holiday wreath on top of someone’s head). Ahhhh! Anyone have any tricks to handling this problem?
    Shawn Miller replied 13 years, 2 months ago 4 Members · 8 Replies
  • 8 Replies
  • Shawn Miller
    July 23, 2013 at 7:43 pm
    [Katheryn Rupert] “Anyone have any tricks to handling this problem?”
    Mocha AE would be my first thought. Roto isn’t fun by any means, but Mocha can take some of the pain out of it. 🙂
    Shawn
  • Doyle Lewis
    July 23, 2013 at 8:47 pm
    do you have a picture of the raw footage you can post, so we can see how close these greens are?
    Doyle Lewis, Assistant Videographer
    thinkck.com
  • Katheryn Rupert
    July 23, 2013 at 9:17 pm
    Thanks, Shawn. I’m trying out Mocha now. I haven’t used this tool before but looks awesome.
    Doyle, here’s a pic of the headband against the green screen. Whenever I do any keying with any other plugin in AE, the majority of the headband goes with it. Any ideas in addition to mocha?
  • Darby Edelen
    July 24, 2013 at 3:10 am
    You may have enough difference in the Green & Blue channels to create a decent matte from those.
    I seemed to be able to get a decent matte by using these on a copy of the footage:
    Channel > Invert
    Color Correction > Channel Mixer
    Monochrome, set Red-Red to 0, Red-Green and Red-Blue to something around 50
    Color Correction > Levels
    Adjust the input black and white levels so that the background screen is black and the foreground wreath is white.
    You can then use this as a luma track matte for a copy of the original footage. Of course this process will be improved by using a garbage matte and doing some work on the edges of the resulting image.
    Darby Edelen
  • Doyle Lewis
    July 24, 2013 at 12:36 pm
    Yep what Darby suggested was how I was going to go about it.
    thinkck.com
  • Katheryn Rupert
    July 26, 2013 at 3:24 am
    Thanks Darby. I tried your suggestion, but something fell apart in the last step with the color correction levels. I couldn’t get the foreground wreath to be white. I’ll keep trying to finesse it, but maybe there’s something else I’m missing from what you did. Any suggestions?
  • Darby Edelen
    July 26, 2013 at 6:02 am
    Can you describe the problem you’re having or upload a photo? Did you make sure that Monochrome was checked in the Channel Mixer?
    Darby Edelen
  • Shawn Miller
    July 26, 2013 at 5:40 pm
    [Katheryn Rupert] “Thanks, Shawn. I’m trying out Mocha now. I haven’t used this tool before but looks awesome.”
    Mocha is awesome! It’s saved me more than a few times in the past. As Dave suggests, Roto Bush can also be pretty effective on footage like this. Both tools take a bit of patience up front, but you really can realize a huge time savings on the back end. Just out of curiosity, what camera was this shot on? Also, is it possible to see a full resolution frame?
    Shawn
