Activity › Forums › Apple Final Cut Pro Legacy › There must be a kid that has figured this out !!! FCP BATCH EXPORT
Posted by Craig Roy on November 9, 2007 at 9:02 amok morning all,
We are rendering out a million zillion HDV PAL 1080i to PAL 8 Bit black magics, as there are network renders out there that will take a AE script, MAYA script, shake script, blah blah blah, why hasn’t someone got one for FCP ? or is there one ?
I am fed up with my editors sitting around counting from a million backwards as batch export stops FCP in its tracks ….
FCP 6.0.1
a trillion Mac Pros
OOOdals of storage and 4 GIG sanAny advice on workflow would be hunky dory
Jason Porthouse replied 18 years, 9 months ago 8 Members · 15 Replies -
Nick Meyers
November 9, 2007 at 10:50 amso what is it you;re trying to do?
is it something you can do in Compressor?
i think compressor can network render,
i know FCP cant.Aussienick
Walter Biscardi
November 9, 2007 at 12:37 pmNetworked rendering is supposedly coming to FCP as part of the Leopard upgrade. Not sure if it will be in the upcoming updates or if it will more of a major upgrade like at NAB in April.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR The new Color Training DVD now available from the Creative Cow!
Jeff Greenberg
November 9, 2007 at 12:52 pmEveryone has nailed it – you need to set up Compressor for clustering;
You may need to reinstall compressor (as well) because likely, the installer had the auto clustering to ‘off’. Last, make sure you have a Gig E network, as you’ll be pushing around files and it’s important that they go fast, fast, fast.
Best,
Jeff G
Principal Instructor
Future Media ConceptsFMCTraining.com
Editorsretreat.com -
Jeff Greenberg
Best,
Jeff G
Craig Roy
November 9, 2007 at 1:11 pmWohoo – your the man Jeff
Will check it out over the weekend !
Craig Roy
November 9, 2007 at 1:17 pmHi everyone,
cheers for the reply – I am trying to make the .fcp project file into a program so I don’t need to render/export 8 bit uncompressed it from FCP – As Walt mentioned mes thinks it is a update … soon – maybe !
Tried importing the .fcp file into Compressor and it didn’t want to know a thing about it
Jeff Greenberg
November 9, 2007 at 1:21 pmYou can’t take the project over – but you can take a sequence (or several sequences) and choose “Send to compresor”…or alternatively export out a QT reference.
Best,
Jeff G
Jason Porthouse
November 9, 2007 at 4:03 pmHi Herbie,
I’m guessing you mean you have a whole load of sequences that you need to export for a number of different uses.
I don’t think FCP has a ‘batch export’ that will enable multiple sequences to be exported. However, exporting reference movie ( and not making it self-contained) will enable you to take this in to compressor – you can then set compressor to export as many flavours as you need. Save your export settings to use again for a quick turnaround, if you’re talking about an action you’ll repeat many times.
HTH,
Jason
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes.*the artist formally known as Jaymags*
David Bogie
November 9, 2007 at 4:27 pm[JeffG] “Everyone has nailed it – you need to set up Compressor for clustering;
You may need to reinstall compressor (as well) because likely, the installer had the auto clustering to ‘off’. Last, make sure you have a Gig E network, as you’ll be pushing around files and it’s important that they go fast, fast, fast.”Jeremy, you may be one of the only humans in this continuum who can claim to have gotten Qmaster to work. I bow.
Network rendering in my world is a sick joke. Adobe never made it work for After Effects and Apple’s promise is simply cruel.
bogiesan
Jeremy Garchow
November 9, 2007 at 9:20 pmFinal Cut Pro does have a batch export. Simply choose all the sequences you want to batch export in the browser, right click and choose batch export. A new window pops up where you can choose the appropriate settings/destinations.
