Activity › Forums › Blackmagic Design › There is no Connection diagrams for Decklink HD Extreme
  • There is no Connection diagrams for Decklink HD Extreme
    Posted by Igor Babic on May 3, 2006 at 6:43 pm
    1. Or I am missing something.
    2. Does 5.4.2 drivers work with this card?
    I have received mine today and I dont wanna lose a day instaling and uninstaling.
    I already have DL SD Extreme and I didnt like 5.5.1 drivers. ( Export to tape window is different and does not read time code from RS 422 if you jog in point on the machine, you have to put TC manually by typing. But insert assemble is frame accurate without tweeking. I have also on my first preview render jerky playback so uninstal them wright away because I didnt have time for more experimenting )
    Igor Babic replied 20 years, 5 months ago 2 Members · 2 Replies
  • Kristian Lam
    May 4, 2006 at 7:09 am
    You’ll definitely need v5.5.1 in order to use the DeckLink HD Extreme card. We’re still updating our website so the connection diagrams will come in due time. Do bear with us. However, it is the same as your DeckLink Extreme SD card. The only addition is Y/C capture for which you’ll need to use the Y, B-Y cable as input/output.
    regards
    Kristian Lam
    Blackmagic Design
  • Igor Babic
    May 4, 2006 at 9:22 am
    Thanks Kristian, sorry for my impatience.
    Can you change this RS 422 capture driver interface inside premiere pro 2 that has no actual time code readings (like in 5.4.2 drivers)? It is anoying that you must enter TC manually.
