Activity Forums Blackmagic Design There is a solution for DeckLink and Cleaner “green” codec problem!
  • There is a solution for DeckLink and Cleaner “green” codec problem!
    Posted by Dv_boyz on July 1, 2005 at 3:14 pm
    Over the past year, I have seen many posts about CleanerXL not working with 8bit and 10bit DeckLink QuickTime files (they just show up as a “green” screen). Also, Cleaner 5 can read the files ok, but has a 2gb limit. The answer to both problems is to make a QuickTime reference file. Poof! The files work fine in both XL and Cleaner5.
    Hope this helps some people.
    Dan
    Accountneedsrealnameupdate replied 21 years, 2 months ago 2 Members · 1 Reply
  • Accountneedsrealnameupdate
    July 13, 2005 at 10:47 pm
    Thanks for that tip, it was big problem for us a while ago and I eventually gave up on it. Just to clarify you just open it in QT pro and save a reference file into the same folder? I’ve had so much trouble with the reference quicktimes coming from Mac to PC that I’ve always stayed away from them.
    Glenn Stewart
