Activity › Forums › Apple Final Cut Pro Legacy › The Waveform Cache Files Folder does not have read/write access
  • The Waveform Cache Files Folder does not have read/write access
    Posted by Andy Duggan on March 7, 2013 at 6:33 pm
    Hello
    I have read several posts and forums regarding the issue I’m having but I haven’t been able to reslove it yet and I’m getting pretty desperate. Any advice gratefully received.
    When I go to launch FCP the full message I get is:
    Please select a new folder in the System Settings Dialog or correct the problem on disk.
    Then FCP quits before I can go in to the system settings and attempt to resolve this.
    I am on MAcBook Pro OS X 10.6.8 2.66 GHz Intel Core 2 Duo
    The version of FCP is 6
    It has worked without fault for me for years.
    So far I have been through Disk Utility and reset permissions and verified disks and repaired them.
    I have deleted the contents of the Waveform Cache Files Folder and tried deleting the folder itself.
    I have rebooted. tried a PRAM and and SCM restart as per other users with this problem.
    Can anybody offer any suggestions??? Many Thanks.
    Chris Batte replied 13 years, 4 months ago 3 Members · 2 Replies
  • Massimo Alberto croce
    March 8, 2013 at 8:13 am
    Try deleting final cut preferences locate in your home/library/preferences.
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Chris Batte
    May 6, 2013 at 9:04 am
    Did you find a solution? I’m having the same problem but with 10.8.3
