Activity › Forums › Apple Final Cut Pro Legacy › The timecode on my mini DV tape is not the same on clip when captured.
  • The timecode on my mini DV tape is not the same on clip when captured.
    Posted by James Riley on February 2, 2006 at 1:51 am
    The producer notes are of the time code that is on the tape.
    I have one tape where the time code on the clip and tape are the same, but the other clips are slightly off to way off.
    How do I…..Get them to match every time?
    JR
    John Pale replied 20 years, 8 months ago 4 Members · 4 Replies
  • Shane Ross
    February 2, 2006 at 1:56 am
    The odd thing is that is should match every single time…if you captured properly.
    You didn’t capture some of the footage with your device control set to UNCONTROLLABLE DEVICE and Capture Now did you? That will ignore the timecode on the tape and generate it’s own.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Alexander Gao
    February 2, 2006 at 3:09 am
    Does timecode appear if captured over 1394 interface? (Just a personal question)
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
  • James Riley
    February 2, 2006 at 3:54 am
    *** Firewire NTSC with capture now
    *** yes….it does
  • John Pale
    February 2, 2006 at 5:26 am
    do you have it set to ignore timecode breaks?
    if so, all code after a break will be wrong.
