Activity Forums Adobe After Effects The Text flicker of Scrolling vertical text!
  • The Text flicker of Scrolling vertical text!
    Posted by Glen Jennings on March 13, 2007 at 8:31 pm
    This seems to be one of the trickiest problems- scrolling vertical end credits for a video seems to flicker and get caught inbetween the scan lines causing it to appear that it is stuttering instead of a fluid move.
    I am trying to use the graph editor to adjust velocity.
    Does anybody have an antidote?
    I heard that if the movement was sped up it would not flciker but unfortunately the text has to be readable.
    help!
    Rod Santoyo replied 17 years, 5 months ago 2 Members · 2 Replies
  • Glen Jennings
    March 13, 2007 at 9:43 pm
    Thank you Dave,
    This is by far the most comrehensive solution I had. One quick question: This is going into an HD time line in Final Cut Pro and is a 1280 x 720 comp in After Effects, since HD has no fields, would that change how you would approach this?
  • Rod Santoyo
    March 31, 2009 at 7:05 pm
    Hi Dave, thnx for this kind of help.
    I am atually working with an Autodesk Inferno. Ive been trying to do some credit rolls but all of them had the “flickering” problem.
    Im workin on a 24 fps project and using a 2048 X 23000 .Tiff credit graphic. So u r saying that i have to get the graphic final position by multiplying 24 by some big number? That will do it??
    Thanx again for ur help.
    Rod
