The screw for PCIe Slot got loose and keeps spinning!
Hi. I am not sure which forum I should put this, but I put it here since many of FCP user might have the same experience…
I just installed a new card in PCIe-slot on G5. But the screw won’t get tight, keeps spinning. maybe the screw hole got loose… (and I dropped this screw inside G5 a couple of times… ! It took me an hour to pick this up! I used clip and my finger…, such a pain!)
I guess I just need to find a slightly larger screw, right? Or is it good idea to tape it with alminum tape (probably strong with heat) ?
Or maybe I can leave it like this? This card goes to eSATA Drive, so I don’t pull/connect the cables so often.Does anyone have the same experience?
Thank you for reading this.
Takeo
