Activity › Forums › Apple Final Cut Pro Legacy › The quicktime movie clips I’m importing do not match the sequence settings of FCP
Posted by Will Ennis on January 31, 2008 at 11:46 pmHello,
i was wondering; How do I change my quicktime clips so that they match the sequence settings of FCP?
Because whenever I import a quicktime clip into FCP a warning pops up asking me if I want to change the sequence settings of FCP to match the clip. And when I click ‘yes’ the audio is off slightly from the video, so it looks like a bad lip synching job when the person on film is speaking.any suggestions on what to do?
WillOliver Juric replied 18 years, 7 months ago 4 Members · 16 Replies -
Don Greening
February 1, 2008 at 12:47 amWhat is the codec used in your QT movies? What audio compressor is used? While your QT movie is playing hit Apple-I to find this out.
– Don
David Roth weiss
February 1, 2008 at 1:09 amSee the answer to your problem in my answer to an earlier question at https://forums.creativecow.net/readpost/8/973266
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Will Ennis
February 1, 2008 at 2:32 amHi Don,
the codec is h.264 but I’m not certain I understand what an audio compressor is…
Could you explain that to me?Will
Don Greening
February 1, 2008 at 2:47 amThe QT movie info window will also tell you what compressor was used on the audio. It’s separate from the video codec but the information will still be listed under “Format” in the get info window.
– Don
Will Ennis
February 1, 2008 at 4:10 amHey Don,
So I looked at what the format says. Is the 16-bit integer the compressor?
If so, what is the next step?Thank you again by the way,
I really appreciate the help,
Will -
Don Greening
February 1, 2008 at 4:55 amThe first line in the format section will tell you what the audio encoder is, but yes, the 16 bit Integer is part of it and refers to the audio bit rate. But there should be something before that describes what the actual audio decoder is. Just copy everything in your get info window and then paste it into a post here so I can read what you’re dealing with.
DId you try the recommendations of the other poster (David) yet?
What I’m trying to determine is if the audio settings of the QT you’re trying to import into FCP match the sequence settings. The audio decoder for your QT movie might not even match what FCP has, which might be the reason you’re having sync issues.
– Don
David Roth weiss
February 1, 2008 at 7:16 am[will ennis] “the codec is h.264”
Will,
h.264 is not an editing codec, it is a distribution codec. This could be your problem. Transcode to an editing format using Quicktime and see if that solves your issue.
David Roth Weiss
Director/Editor
Will Ennis
February 1, 2008 at 6:58 pmHey Don,
Yes, I tried what David recommended but it did not work. Here is the full info on the format of the Qt file.
Format: 16-bit Integer (Little Endian), Stereo (L R), 44.100 kHz
H.264 Decoder, 640 x 480, MillionsWill
Will Ennis
February 1, 2008 at 7:01 pmHi David,
How exactly do I transcode to an editing format in Quicktime?
I’m very uneducated in this regard.Will
David Roth weiss
February 1, 2008 at 7:06 pmI’ve got to go walk the dog, then I’ll come back with a quick explanation… See ya in twenty…
David Roth Weiss
Director/Editor
