Activity › Forums › DaVinci Resolve › The Quadro 4000 can be Gui +GPU Power ?
Posted by Gabriele Turchi on April 22, 2011 at 5:12 pmI did not knew this ,
kaku ito on reduser pinted out that the 4000 can be both GUI + “GPU power”…i am wondering if it can proved both t the same time (so taking care of teh GUI + add power as GPU …)
does anyone tried 2x 4000 on the macpro (so without the cubix and without the GT120 ?
or how about a 4000 (gui slot)+ 285 on the macPro ?
Does the 4000 (used on the GUI slot) provide Power for grading as well ( the GT120 i guess does not at all …)
thanks
g
Eric Santiago replied 15 years, 1 month ago 10 Members · 27 Replies -
Rémi Berge
April 22, 2011 at 5:29 pmyou can use a Quadro 4000 (or 285) for GUI and GPU
you can use a Quadro 4000 (or 285) and quadro as GUI 4000 (or 285) as the GPU.
with a single card, the machine is slower.
if you need a good graphic card (GUI) for other applicalions, you can effectively replace the GT120 by more powerful. -
Gabriele Turchi
April 22, 2011 at 5:35 pmaccording to the Mac PDF guide the 285 cannot be GUI …
But my question is :
is 4000+285 or 4000+4000 (on a macpro tower (no cubix) more powerful (more nodes of correction in realtime ) than 285 + 120 (or 4000+120) ?
thanks
g
Rémi Berge
April 22, 2011 at 5:51 pmexcuse
the answer is no, the resolve will use for the processing the only
Card considered as the GPU.
Otherwise I confirm that resolve also works with a single Card GPU + GUI.(4000 or 285) -
Gabriele Turchi
April 22, 2011 at 5:58 pmthanks remi
so to make sure I understood :
on a dual card configuration :the 4000 if used as GUI does not provide any extra GPU power (so it’s like having a GT120 )ps:do you work for blackmagic ?
thanks
g
Dwaine Maggart
April 22, 2011 at 6:01 pmWhile you can use a single card (a 4000 for instance) for both the GUI and GPU, the performance will be much worse than using a separate card for each, which is why we don’t recommend doing that. In fact, we recommend you DON’T do that. But it’s your machine, you can do whatever you want. Just be aware of the consequences to performance.
Using 2 4000 cards, one for the GUI and one for the GPU, will not give you any better GPU performance than using a single 4000 GPU and any other card for the GUI. Using a second 4000 card for the GUI should make the GUI more responsive than say a GT-120, but it won’t improve the GPU performance.
Dwaine Maggart
Blackmagic Design DaVinci Support -
Rémi Berge
April 22, 2011 at 6:06 pmyou have understood well, despite my very bad English.
no I do not work for them, at least I’m not paid. 😉 -
Sascha Haber
April 22, 2011 at 6:10 pmHey Gabriele,
it’s more like this :
You use two cards and have to decide which one will do the processing .
Only the secondary will do it.
You use only one and force Resolve to do both on one .
You will take a 25% percent performance hit but gain the power for Smoke, Premiere , Maya or anything else .A slice of color…
DaVinci 7.1 OSX 10.6.6
Dual Xeon 2,4 RAM 24 GB
RAID0 8TB eSata 6TB
GTX 285 / GT 120
Extreme 3D+ WAVE -
Gabriele Turchi
April 22, 2011 at 6:15 pmgot thanks all .
that’s honestly what I thought ,but than I read that post on reducer that confused me (basically saying that 2x 4000 would give more GPU power than 120+4000)
but it is not
ps:using the cubix :doubling the numbers or GPU card ,dies double the number or realtime nodes ?
or is a % increment ?at the moment I have 120+285 ,and I get around 8nodes with blur on HD DPX …if I add another 285 (cubix) will I get 16 nodes ? or less ?
thanks
g
Andreas Wideroe
April 22, 2011 at 7:32 pmThe 285 ( I have only 1) works fine both as gui and gpu om my system.
Norsk Smalfilm AS
https://www.smalfilm.noFilmshooting | Com
https://www.filmshooting.com -
Mikhail Puzyrev
April 22, 2011 at 7:57 pmI have single gtx480 driving 2 monitors and doing cuda processing. But it’s hackintosh. On a Mac pro you can try gtx470 from macvidcards. It’s the most powerful card you can put into your Mac pro. (they have 480 as well, but it needs external power supply)
