Activity › Forums › Adobe After Effects › the problem is still with me about camera in element 3d
Evan Morris replied 8 years, 8 months ago 12 Members · 23 Replies
Mike Mathes
May 2, 2014 at 4:00 pmIf none of these tricks worked for you I found that you can also adjust the camera cut-off settings to solve this problem. For me, adjusting the ‘camera far plane’ setting to 500,000 seemed to do the trick.
Sylvester Huikeshoven
February 17, 2017 at 10:40 amThis even worked for me with a camera dislyaing problem in 3D layers. Thanks
Evan Morris
December 21, 2017 at 3:58 pmJon Secchis, YOU are the hero of this post! Well done. If you don’t work for creativecow.net, you should.
