Activity Forums Sony Cameras The “No Media” Problem
  • The “No Media” Problem
    Posted by Brent Stumpf on January 26, 2009 at 12:39 am
    Hey everyone,
    I cannot for the life of me get the Sony XDcam Transfer program to import my files into Final Cut! Whenever I add a folder, the clips are identified, but the window says “No Media”. I have Final Cut Studio 2, version 2.5.1 of XDcam transfer. I have tried the suggestion of putting the BPAV folder in a different folder and opening it (claims there are no files) as well as bring the .mp4 file into FCP (says Codec Not found. You may using a compression type without the corresponding hardware card)
    I imagine the footage has to be there, but I cannot access it. any help whatsoever from those who have overcome this hurdle would me most appreciated!
    Brent
    Craig Seeman replied 17 years, 7 months ago 4 Members · 4 Replies
  • Michael Palmer
    January 26, 2009 at 2:24 am
  • Brent Stumpf
    January 26, 2009 at 2:42 am
    Michael,
    Turns out the problem was as simple as Quicktime needing an update. Appreciate the help though.
    Best,
    Brendan
  • David Wilbert
    January 28, 2009 at 6:57 am
    I have BPAV files on my hard drive – I have XDCAM transfer 2.8.0. I have the most current update of Quicktime. Can I view my files through XDCAM transfer in a Quicktime window, if so, can someone please help me out.
    I’ve opened up a few of the files and they have opened up in Quicktime, but only the audio portion.
    Can someone please help me out with this problem?
    Also the files that I opened in Quicktime – I can no longer use the “add source” in XDCAM to open those files in XDCAM transfer using the Quicktime window!
    I hope this makes sense! Please try to help!!
    Thank you!
  • Craig Seeman
    January 28, 2009 at 3:15 pm
    The contents of a BPAV (MP4) can be viewed in ClipBrowser, XDCAM Transfer, VLC. They can not be viewed in Quicktime. MOV can be viewed in Quicktime after XDCAM Transfer as re-wraped the MP4 to MOV (and you have FCP 6.0.2 and up).
