Activity › Forums › Avid Media Composer › the edit rate of the clip (50.000000) does not match the project edit rate site (25.000000)
  • the edit rate of the clip (50.000000) does not match the project edit rate site (25.000000)
    Posted by Paul Donahue on October 24, 2013 at 7:52 pm
    I shot footage on a Canon XF 305 camera at 50 Mbps 1280×720, exported the MXF clips from the Canon XF Utility, and tried to bring them into an Avid MC 6.5.3 project that was set at 720p/25 and received the above message
    the edit rate of the clip (50.000000) does not match the project edit rate site (25.000000).
    Is there a way to still bring these clips into the project? Avid MC does not have a 720p/50 project setting and the XF 305 does not have a 1280×720 25Mbps setting, but there must be a way to bring this type of clips into an Avid project.
    Thanks in advance,
    Paul
    Paul Donahue
    Media Eye
    http://www.mediaeyemedia.com
    Paul Donahue replied 12 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Richard Sanchez
    October 24, 2013 at 7:56 pm
    I’m pretty sure MC does have a 720/50 project option. Try creating a new project.
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Paul Donahue
    October 24, 2013 at 8:11 pm
    Unfortunately, there is not 720/50 project option. I don’t really understand why.
    Paul
    Paul Donahue
    Media Eye
  • Michael Phillips
    October 24, 2013 at 8:30 pm
    Here is what I see when creating a new project, and 720p/50 is definitely there. But it is unfortunate that Media Composer still doesn’t have a 1080p/50 and 1080p/59.94 project type. For now you need to choose between resolution and frame rate. If you want all 50 progressive frames to edit on, then choose 720 (reducing resolution) or choose 1080i/50 where each frame becomes a field reducing vertical resolution by half and editing on ever other “frame”.
    Michael
  • Richard Sanchez
    October 24, 2013 at 8:32 pm
    I’m using MC 6.5.2.
    Richard Sanchez
    Los Angeles, CA
  • Paul Donahue
    October 24, 2013 at 8:40 pm
    i’ve now opened up a new project and i can choose 720/50. Thanks!
    Paul
    Paul Donahue
    Media Eye
  • Clayton Lonie
    October 25, 2013 at 7:21 am
    Open clips in 720/50… Then create your 25p project.
    Then open the 720/50 bin in the 25p project … Avid will
    Then handle all conversions for you.
    Avid Media Composer Expert User. (Modist, I know!!!)
  • Paul Donahue
    October 25, 2013 at 11:26 am
    Thanks for this advice. That explains perfectly what I would like to do.
    Sincerely,
    Paul
    Paul Donahue
    Media Eye
