Activity Forums Adobe After Effects The Double Role Shots
  • The Double Role Shots
    Posted by Vitun Sharma on February 17, 2008 at 9:56 am
    I have my actual actor in the same scene, by shooting each character in separate passes” In a First pass the actor is interacting and in second pass the same actor interacting as well as shaking hands… the stress in on body contact between the two … is this possible to achieve this shot in after effects …. if so how.? plz help me out
    thanks
    Muhaned Abu khumra replied 18 years, 6 months ago 2 Members · 1 Reply
  • Muhaned Abu khumra
    February 17, 2008 at 11:52 am
    Hi … if there is no movement in your camera (Still shot)
    that is verey easy put first frame with the actor and put over that layer the same actor with a diffrent passes and mask the stress in on body contact between the two actors manual and key it frame by frame
