Activity › Forums › Apple Final Cut Pro Legacy › the definitive FCP rule of trimming
  • the definitive FCP rule of trimming
    Posted by Aren Hansen on April 27, 2006 at 10:46 pm
    Please help clarify this rule for me. I’m just at the start of a theatrical feature, trying to help get their editor up to speed on FCP. We’re at the
    trimming stage of the tutoring and explaining the exact logicality of FCP’s ripple/trim functionality is proving to be a real beast. Here’s what I’ve come
    up with so far:
    When using the Ripple tool:
    All video and audio clips that begin after the last edit point selected will move.
    UNLESS
    audio points are selected, in which case audio clips will move if they begin after the FIRST audio point selected. Video continues to look at the last video point
    This seems very bizarre. The FCP manual states it as:
    Clip items with In points later in the Timeline than the edit point(s) you are adjusting will move, or ripple, after you perform a rippple edit.
    All other clip items remain in the same position in the timeline.
    This is not a good enough explanation for the mayhem that ensues once multiple asymmetric edits are selected.
    Aren
    Aren Hansen replied 20 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Tom Wolsky
    April 28, 2006 at 2:26 am
    Sounds like you want to do a roll edit rather than a ripple, though it’s hard to tell from your description of what exactly you’re doing.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Aren Hansen
    April 28, 2006 at 6:24 am
    No, I’m trying to explain what happens when you use the ripple tool. What’s the rule? It is much more complicated then the manual states.
    For example:
    Line up tracks like this:
    v1: AAAAAAAAAAAAAABBBBBBBBBBBBBBBBB
    a1: BBBBBBBBBBBBBBBBBBBBBBB
    a2: AAAAAAAAAAAAAA
    If you want to trim the head of the B video clip and need the B audio to stay in sync, you need to also select the edit point in front of the B audio. We don’t want to trim the B audio, just move it in sync with the video. So, we select the tail of the black before the B audio. However, once you do this, your A audio will also move.
    I’m looking for a rule that can be applied in such a way that after edit points are selected, one could apply the rule and predict what will happen when a trim is made. Which clips will move and which won’t. I came up with a rule but I’m not sure it’s complete.
  • Martin Baker
    April 28, 2006 at 10:13 am
    Yes the A audio will move IF it starts on or after the frame that the B audio starts, this is the case in your example and is consistent with what the manual says.
    What’s happening here is that if a track does not have a trim point manually placed then FCP puts in an invisible trim point on that track to keep everything in sync. In your case this invisible trim point is being placed on the tail of the gap/clip before the A audio clip.
    like this (selected trim points in orange, invisible trim point in blue)
    v1: GGGGAAAAAAAAAAAAAABBBBBBBBBB
    a1: GGG
    GBBBBBBBBBBBBBBBB
    a2: GGG
    GAAAAAAAAAAAAAA
    hence why the A audio clip is being moved out of sync when you trim.
    The solution is to place an additional trim point at the head of the clip/gap after the A audio clip. Like this:
    v1: GGGGAAAAAAAAAAAAAABBBBBBBBBBGGG
    a1: GGG
    GBBBBBBBBBBBBBBBBGGG
    a2: GGGGAAAAAAAAAAAAAA
    GGGG
    Martin
    Digital Heaven, London UK
    ________________________________________
    AutoMotion – 0-60 graphics in 5.2 seconds – Now Shipping
  • Martin Baker
    April 28, 2006 at 10:20 am
    OK thinking about it, the manual is a bit wrong here because it doesn’t say clips starting on the same frame only “starting later”.
    Martin
  • Tom Wolsky
    April 28, 2006 at 10:45 am
    What Martin said. Except that in the situation you describe, where there is black or a gap front of the B audio. In that instance your audio A track doesn’t move. Only the B vision on V1 and the B audio on A1 are affected by the ripple. What Martin describes only occurs for me if there is a sync clip in front on V1/A1/A2, and you have asymmetrically selected both the incoming B vision and the outgoing audio on A1 and A2. In that instance the A audio on A2 will slip out of sync. In that instance you need to select only the incoming B vision on A1, outgoing A1 audio and the back end of the A2 audio as Martin described.
    All the best,
    Tom
  • Tom Wolsky
    April 28, 2006 at 10:49 am
    Love your auto motion. Fantastic tool if you’re doing a lot of this stuff, for long form especially.
    All the best,
    Tom
  • Aren Hansen
    April 28, 2006 at 5:55 pm
    Thanks a lot guys. I suppose it is doing what you’d want it to do. I appreciate you taking the time to discuss this. See you,
    Aren
