Activity Forums VEGAS Pro The computer has rebooted from a bugcheck…
  • The computer has rebooted from a bugcheck…
    Posted by Eugen Gorceac on February 7, 2008 at 10:58 am
    Hello,
    I am on Windows XP SP2 Pro and Sony Vegas 6.
    In My video project I also use proDAD’s Heroglyph 2 and Adorage.
    2 times I tried to live the rendering project for nighttime. I am trying to generate a DVD Architect compatible mpeg2 file. Every time my computer restarts at certain time saving a .dmp file with the error. Of course if computer restarts I loose all rendering job.
    I don’t know what is causing the restart, may be anyone from you can help me by checking the .dmp file.
    That is the error:
    The computer has rebooted from a bugcheck. The bugcheck was: 0x1000007e (0xc0000005, 0xf82c5f4c, 0xf8aecc58, 0xf8aec954). A dump was saved in: C:\WINDOWS\Minidump\Mini020708-01.dmp.
    For more information, see Help and Support Center at https://go.microsoft.com/fwlink/events.asp.
    And here is the attached .dmp file: https://moldova.worldcarp.org/forum_files/files_storage/short_time/stockyard/Mini020708-01.dmp
    The beat never fades!
    Laszlo Kovacs replied 18 years, 7 months ago 3 Members · 5 Replies
  • Laszlo Kovacs
    February 7, 2008 at 4:44 pm
    I’m not sure at all that I’ll be in help for you, just a couple of ideas:
    Switch off the automatic reboot on crash. (My computer/properties/special/startup, recovery options: click setup button and uncheck the automatic reboot – the actual captions may differ, I translated them back to english from hungarian ;)).
    That will leave the blue screen on crash, and you can read which dll, or device driver caused the crash. That information might help.
    From https://www.memtest86.com/download.html download memetest bootable iso, unzip, burn iso to a cd, boot in and leave it running the whole night.
    If there’s a problem with your RAM/Motherboard you’ll see it as memory errors. (Take out the CD, so that memtest cannot reboot, as memtest may crash too, so you can see in the morning wether it worked all night OK, or crashed. Of course if memtest crashes, then there’s a serious problem with your RAM/MoBo. )
    If the crash occurs always after a while of working/rendering,
    some sort of overheating may also be a cause.
    Check all of your systems fans, and the motherboard for dust.
    Clean if necessary.
    Regards
    K.L.
  • Eugen Gorceac
    February 8, 2008 at 9:10 am
    Thanks Laszlo,
    Probably I’ll have to go through that test routine if no concrete diagnose can be established by anyone…
  • Allen Zagel
    February 8, 2008 at 12:09 pm
    Laszlo
    Are you near Budapest? We’re coming there in March for a visit.
    Allen
    ASX Media Productions
    https://www.asxvideo.com
  • Laszlo Kovacs
    February 8, 2008 at 3:38 pm
    Eugene, you could also setup on an other computer (let’s say on a laptop) the same softwares, and try to render there. If it fails, then it’s about software problem (incompatibility, other error etc.)
    Regards
    K.L.
  • Laszlo Kovacs
    February 8, 2008 at 3:41 pm
    [Allen Zagel] “Are you near Budapest?”
    Yes, I’m the nearest.
    I’m living here 😉
    Regards
    K.L.
