Activity Forums Maxon Cinema 4D The Colors are Correct in the Reflections not on the Object
  • The Colors are Correct in the Reflections not on the Object
    Posted by Sean Lloyd on December 8, 2022 at 4:33 am
    This is a weird one. All the colors read correctly in the reflections not on the set I made. Some in the middle are but the rest are wrong. Each panel is backlit by a colored light. I don’t get it.
    Any ideas? I’m almost finished but this problem is blocking me from finishing it.
    Sean Lloyd replied 3 years, 7 months ago 2 Members · 5 Replies
  • Michael blaq
    December 9, 2022 at 1:24 pm
    Are you rendering with Element 3D or is this a Cinema 4D rendered sequence?
  • Sean Lloyd
    December 9, 2022 at 8:02 pm
    It’s rendered in C4D with the physical setting.
    And thanks very much for the reply. I’ll look up what Element 3d is because I have never used it.
  • Michael blaq
    December 11, 2022 at 10:41 pm
    Is it possible for you to share a scene file and a sample of what you are trying to achieve with me?
  • Sean Lloyd
    December 11, 2022 at 11:00 pm
    What I’m trying to achieve is what is in the photo. I just need the colors to show up correctly.
  • Sean Lloyd
    January 26, 2023 at 7:41 am
    Just wanted to update. I finally figured out what may be obvious to many. My problem was in the render settings. I didn’t have COLOR MAPPING checked in my render. Once I changed it it fixed my problem.
