Activity › Forums › Adobe Audition › the Big Noise
  • the Big Noise
    Posted by Norman Frizzle on October 2, 2005 at 10:11 pm
    Does AUDITION have a formula to minimize microphone wind roar?
    If not, has anyone developed a technique to best-guess what portion of the audio is the desired sound and what is wind, then remove the latter with minimal artifacting?
    Willie Toth replied 21 years ago 2 Members · 1 Reply
  • Willie Toth
    October 3, 2005 at 1:57 am
    Norman,
    Check out Audio secrets 1 tut from Aug. 4Th, one thing he doesn’t mention however is that you can go into digitizing real easy so take the noise out in small amounts starting about 50 to 60 % and drop that percentage by 10 to 15% at each attempt … If you use the Parametric EQ you may be able to isolate the freq. and remove it that way as well … If you don’t have the success you are looking for you can always E-mail me a sample MP 3 of a minute or so to loganonestudio@aol.com and I can see if I will be able to help … Don’t expect to remove the noise completely but you should be able to at least pull it into the background …….. WILLIE
