Activity › Forums › Adobe Premiere Pro › The best way to adjust volume in Premiere
  • The best way to adjust volume in Premiere
    Posted by John Stanowski on August 27, 2008 at 4:57 am
    Hey, I’m a little new to PPRO so sorry if this is a stupid question.
    I want to adjust my volume levels dynamically on a per clip basis while I’m listening to the audio. (This is for clips already in a sequence.)
    My problem is, it seems the only way to adjust the volume while the clip is playing is to adjust it in the Effects Control panel. Which isn’t a problem for me except for the fact that it always keyframes all of my adjustments. I have to unclick the stopwatch to remove the keyframes everytime.
    Is there another way to do this? I can’t adjust volume using the rubberband on the timeline because everytime I touch it the clip stops playing.
    John Stanowski replied 18 years, 1 month ago 2 Members · 3 Replies
  • Ann Bens
    August 27, 2008 at 10:45 am
    Try the audio mixer.
  • John Stanowski
    August 27, 2008 at 2:26 pm
    But I need to adjust volume on a per clip basis. From what I understand the Sound Mixer works with entire tracks. And from what I’ve read it also records keyframes for all your actions.
  • John Stanowski
    August 28, 2008 at 1:21 am
    I figured it out. Actually I feel like a dolt. All I have to do is de-select the Stopwatch on the Level Slider under the Volume Effect. Then I can let the clip play and adjust the level and no keyframes are recorded.
