Activity › Forums › Adobe After Effects › “The AVI file is not of the expected format” ERROR message…
  • “The AVI file is not of the expected format” ERROR message…
    Posted by Pat Tremblay on February 25, 2006 at 11:35 pm
    Bought a new PC.
    -Installed AE7 & re-opened a project made earlier in AE 6.5.
    -I had to reload footage since files were on a new drive.
    -It either crashed, or other times opened them but mentioned “The AVI file is not of the expected format” (-2147205018) (53 :: 33)
    -Tried to reload images (PSD, JPG) and even audio files (WAV) and the SAME “AVI not expected” error message pops up again, and doesn,t load it…
    -Freaked out since I got DO this project now.
    -Uninstalled AE7 figuring there was a transition bug between the 2 versions.
    -Downgraded by installing my AE 6.5
    -SAME problem happens now………..
    Note: all independent files play perfectly well in Media Player. Pics open elsewhere too.
    What in the name is going on???
    Pat
    Additional info:
    -Got a NVIDIA EN7800GTX card (tried to upgrade firmware V 81.94 but get an error message on setup: “The NVIDIA setup program could not locate drivers that are compatible with your current hardware. Set up will now exit”.
    -ASUS A8N-E board: firmware upgraded ok.
    -Got XP w/ SP1 & 2
    Pat Tremblay replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
