Activity › Forums › Apple Final Cut Pro Legacy › The art of sync audio with video
  • The art of sync audio with video
    Posted by Mahmoud Morsi on June 18, 2010 at 11:27 pm
    Hello gurus of FCP, really im a graphic designer, I’m using FCP a little bit at my work, but im not an Editor, I find it so hard to sync the audio with video while editing, Please any tips or tricks or sources to learn from the Art of Editing and sync audio with video, I know you will say you will have to practice but im not an Editor and i can’t find any where to practice, Please help me .
    Eric Wheelwright replied 13 years, 4 months ago 9 Members · 16 Replies
  • 16 Replies
  • Shane Ross
    June 19, 2010 at 12:04 am
    Do you have SLATES? Those clapper boards where people call out the take and the shot, and then clap it shut, so that you have a visual and audible reference to sync to?
    The manual is a great place to look for this info…
    https://documentation.apple.com/en/finalcutpro/usermanual/index.html#chapter=40%26section=0%26tasks=true
    Shane
  • Mahmoud Morsi
    June 19, 2010 at 12:22 am
    Thanks Shane for your replay, I knew the SLATES you mean, but i didn’t reached this point of editing to have this work, I mean i can’t sync the visual with audio in other hand, I can use the FCP pretty good but i feel sometimes i don’t have that sense that every editor have, Please any suggestions ?
  • Shane Ross
    June 19, 2010 at 12:33 am
  • Mahmoud Morsi
    June 19, 2010 at 12:50 am
    Thanks Shane, but you didn’t understand me, I need to learn the art of sync, im looking for links that can help me in this matter, I want to read to reach it i want to learn.
  • Shane Ross
    June 19, 2010 at 1:06 am
    What “art?” This is a technical task handled by assistant editors. You find the visible slate hit (when it closes), and mark IN on your VIDEO track. You scrub through the audio until you hear the slate clap…go frame by frame until you hear the first *tick* of the hit, and then mark IN. Then you highlight both clips, and use the MERGE CLIPS option, and use IN points.
    It’s that simple.
    Shane
  • Mahmoud Morsi
    June 19, 2010 at 1:19 am
    Please check these video and you will understand me, I’m sorry
    https://vimeo.com/12583356
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Shane Ross
    June 19, 2010 at 1:46 am
    AHA! You mean cut video to the beat! Montage stuff, but to the beat of the music.
    Dunno if there is any online reference or tutorial on that. You just mark IN on a beat, then OUT on a beat, and add the clip. Turn SCRUBBING on (Shift-S), and go frame by frame if you want. Make sure your audio waveforms are on if you want to see the music visibly.
    Shane
  • David Roth weiss
    June 19, 2010 at 5:24 am
    Just as some people are born dancers and others can’t dance if their life depends on it, some editors are born with rhythm, some have to learn it, and others just don’t have the beat and never will. Which one are you?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Scott Sheriff
    June 20, 2010 at 5:43 am
    Part of the ‘art’ is to not always cut on the beat. Cutting on the beat gets old fast. Good drummers use ‘ghost notes’, rests, and fills to break the monotony, while maintaining a rhythm. As an editor you can do the same. One example, you can cut on the ‘beat’, like on the snare a few times, then not cut the next time it comes around, then make the next cut on the kick drum, or making a bunch of quick cuts on the Hi-Hat. Avoid being predictable, to help keep it fresh.
    Also what you do has to make ‘sense’ with the rest of the music. Don’t ignore the flow or emotion of a song, just to cut on a beat.
    Scott Sheriff
    Director
    SST Digital Media
    https://www.sstdigitalmedia.com
  • Mahmoud Morsi
    June 20, 2010 at 10:12 am
    actually I’m not an Editor but I’m using FCP at my work, I can’t dance :D, Thanks for your response David.
