Activity Forums Adobe After Effects The 9.0.2 Upgrade thread.
  • The 9.0.2 Upgrade thread.
    Posted by Dumeyni Arnaud on May 29, 2009 at 1:42 pm
     Crash on quit if the active workspace when After Effects starts includes a ScriptUI Panel.
    (48419, 49138, 49163)
     Several memory corruption issues; fix should improve overall application stability.
     Crash on startup on computers with very old OpenGL drivers, or unsupported video card
    manufacturers. (49698, 2266571, 2283657, 49758)
     Crash on startup due to a corrupt XML file in the preferences directory, such as used by
    workspaces, dialog boxes, and Pixel Bender. Now, the corrupt file will be appended with
    a .old extension so that startup can proceed. (49837)
     Crash on startup due to unsupported codec. Now, a warning message will identify the
    unsupported codec and associated file name. (49876)
     When a PDFL crash occurs during startup, more information is now provided, indicating
    that a bad font may be causing the crash. (49901)
     (Windows only) Drawing surface errors and short RAM previews due to exhaustion of
    GDI resources (handles).
    Now, you should have better memory usage, resulting in longer
    RAM previews and improved performance. (49912)
     Cannot open DPX file that can be opened in Photoshop CS4; file converted from
    Phantom .cine to DPX using Glue Tools. (49330)
     “After Effect error: internal verification failure, sorry! {fill me in}” error trying to import
    multi-image element DPX footage, such as from a Northlight Film Scanner. (50121)
     Audio conforming failure when importing certain FLV files. (2319601)
     Crash when using Pixel Bender effects, GPU-accelerated effects, and Cartoon effect in
    low-memory situations.
    Instead of being marked invalid, Pixel Bender effects can be
    reapplied when memory becomes available. (2276200, 50174)
     Crash in the Puppet effect when generating the mesh on a complex shape (possibly
    when Expansion is zero). (49971)
     (Mac OS only) Crash in the Puppet effect when pasting keyframes into a non-keyframed
    Puppet pin Position property. (49508)
     “could not convert unicode characters (23::46)” error applying CC RepeTile effect in
    Chinese OS (49988), or crash using CC Particle World on Mac Pro 8-Core i7 (Nehalem)
    machines (50366).
     Crash trying to interrupt rendering (e.g., dragging to adjust values) for the Fog 3D, Depth
    Matte, or ID Matte effect when placed after other effects (49491, 49492, 49493); for
    5/18/2009 Adobe After Effects Creative Suite 4 9.0.2 Read Me 2 of 3
    Fractal Noise and Turbulent Noise effects (50111); and for EXtractoR and IDentifier
    effects when placed after other effects. (49921)
     Crash when deleting the Tone effect from one composition, when that composition is
    used (nested) in another composition. (50081)
     (Mac OS only) Incorrect Mac type/creator codes for OpenEXR, PICT, PNG, TIFF, and
    Cineon rendered files, which made them unrecognizable by Final Cut Pro. (49811)
     Crash on quit or close of project after multiple layers with various video/audio states
    (active, solo) are copied. (49632)
     Crash on quit with layers on the clipboard that are adjustment layers with effects with
    points or collapsed layers. (50079, 49922)
     Incorrect dimensions of a multiple-layer Photoshop file imported as a composition with
    cropped layers and merged layer styles. (50146)
     (Mac OS only) “invalid file location specification (must include name) (3::45)” error on quit
    if you create or open a project containing Particle Playground effect. (49892)
    Known issues
     Crash dragging RED footage in Premiere Pro that was imported from an Premiere Pro
    (.prproj) file exported from an After Effects composition containing RED footage with
    audio. (2319785)
     (Mac OS only) Can’t import R3D file located in a folder with a Japanese name.
    Workaround: Change the folder to a non-Japanese name.(2315531)
     User clip name is ignored when importing Avid MXF or P2 files. After Effects names the
    footage item based on the file name, not metadata in the file. (2313280)
     Audio conforming failure warning when trying to open the RED R3D Source Settings
    dialog box while a R3D file with embedded audio is still conforming. Workaround: Wait for
    the footage to finish conforming before opening the dialog box. (50395)
    Currently downloading !
    Todd Kopriva replied 17 years, 3 months ago 2 Members · 1 Reply
  • Todd Kopriva
    May 29, 2009 at 2:40 pm
    I have an extensive post on the update, which I announced in this thread.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
