Activity › Forums › Apple Final Cut Pro Legacy › That Damn Color Ball!! – Crash
  • That Damn Color Ball!! – Crash
    Posted by António Carvalho on February 20, 2008 at 5:17 pm
    Recently, when i want to play a video in the timeline, i get the color ball, and it stays there until i force quit.
    The system works fine, only Final Cut Pro not responding.
    I’m working on a project timeline with this settings:
    HDTV 1080i(16:9)
    Square
    Upper Odd Fields
    Pal
    Apple ProRes Codec (HQ)
    My system info:
    Mac OS Tiger
    2×3 GHZ Quad-Core Intel Xeon
    9GB 667 MHZ DDR2 FB-DIMM Memory
    All software updated
    Hardware:
    Connected via PCI Extreme 4LANE to a BlackMagic Multibridge Extreme
    Firmware and software with latest updates
    If someone has an ideia on this, i’d appreciate the help
    Mark Maness replied 18 years, 7 months ago 4 Members · 4 Replies
  • Rainer Wirth
    February 20, 2008 at 5:35 pm
    Try repair your permissions in the Disc programm of your system.
    Rainer
  • Mark Maness
    February 20, 2008 at 8:35 pm
    I would also suggest that you remove the one gig of Apple memory bringing your total to 8 gig. FCP works best in multiples of 4 (and works with 2 gig, too). So you can have it configured to 2 gig, 4 gig, 8 gig, 16 gig. This is the specs from Apple and I haven’t had a single issue with this.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Jeremy Garchow
    February 20, 2008 at 9:38 pm
    [Wayne Carey] “FCP works best in multiples of 4 (and works with 2 gig, too). So you can have it configured to 2 gig, 4 gig, 8 gig, 16 gig. This is the specs from Apple and I haven’t had a single issue with this.”
    Here’s the white paper on that:
    https://docs.info.apple.com/article.html?artnum=304492
    Also, what kind of drives are you playing back from?
  • Mark Maness
    February 20, 2008 at 10:46 pm
    Good catch, Jeremy!
    I was going to paste that in and got side tracked while editing…
    Wayne Carey
    Schazam Productions
