Activity Forums Adobe After Effects tga sequence loosing frames, please help!
  • tga sequence loosing frames, please help!
    Posted by Dave Rumbelow on September 25, 2007 at 8:04 am
    Hi
    firstly not sure if this problem is with Avid or AE so I’ll post it on the avid board too.
    Hers the problem, I am exporting an 11sec sequence from avid to do some fx work in ae so I export a tga sequence (always worked best for me) however when I import this as footage into ae its only just over 9seconds long.
    composition is
    11sec
    25 fps (working in pal)
    1024×576 (square pix widescreen)
    any ideas?
    Jeff Mcbride replied 19 years ago 2 Members · 2 Replies
  • Dave Rumbelow
    September 25, 2007 at 10:17 am
    my bad!
    forgot to reinterpret footage as 25fps as ae defaults to 30
    anyone know how to set 25 as the default for image sequences?
  • Jeff Mcbride
    September 25, 2007 at 1:41 pm
    If you go to After Effects –> Preferences –> Import you can set up sequence footage fps. Have fun!
    Jeff McBride
    Motion Graphic Designer/Editor
    LimeGreen
    Chicago, IL
    http://www.limegreenproductions.com
