Activity Forums Apple Final Cut Pro Legacy TGA Graphic jumps when Dissolve is used undereath
  • TGA Graphic jumps when Dissolve is used undereath
    Posted by Jeffrey Lonigro on August 11, 2009 at 8:09 pm
    I have two clips that I am using a dissolve in between. When I place a TGA lower third graphic file on top of the clips the TGA jumps up in position at the end of he dissolve.
    Jeffrey Lonigro replied 17 years ago 2 Members · 2 Replies
  • David Roth weiss
    August 11, 2009 at 8:29 pm
    Have you rendered?
    Have you made certain that “Full” is checked in the Sequence>>Render All drop down menu before rendering? It’s not checked by default as it comes from the factory you know.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Jeffrey Lonigro
    August 11, 2009 at 8:43 pm
    Awesome! That was it. Thanks!
