Activity Forums Adobe After Effects TGA from AE for Voodoo
  • TGA from AE for Voodoo
    Posted by Chris Leatherwood on December 6, 2008 at 4:04 pm
    hi I’ve been working with AE and blender to re-create a scene from harry potter. I need to use voodoo to 3d track but it only uses .tga files. How do I export my footage from AE in .tga format?
    Chris Leatherwood replied 17 years, 8 months ago 2 Members · 2 Replies
  • Walter Soyka
    December 8, 2008 at 6:35 pm
    Hi Chris,
    Add your comp to the render queue, and select the “Photoshop” Output Module. Click on the word Photoshop to edit the settings. It will say “Format: Photoshop Sequence” at the top of the Main Options tab. Change it to a Targa sequence.
    I don’t know what Targa settings you need to work with your tracker — you will have a couple different options for resolution, and can turn RLE compression on or off. Some apps cannot read RLE-compressed Targa sequences, but uncompressed Targa sequences can be very large.
    RLE is a lossless form of compression, so if you can use it, you will not lose any quality.
    Walter Soyka, Principal
    Keen Live, Inc.
    Presentation, Motion Graphics & Widescreen Design
    RenderBreak: A Blog on Innovation in Production
  • Chris Leatherwood
    December 8, 2008 at 6:41 pm
    Thanks so much the rle compression was great and ae did everything perfect. Thanks again!!
