Activity › Forums › Maxon Cinema 4D › Texturing issue
  • Brian Jones
    March 2, 2018 at 4:29 pm
    since you haven’t said I will assume you are trying to use a circle spline swept on a helix spline I will also assume you are trying to use an image of text… Rotate the text image 90° so it’s running up and down rather than left – right that should get it to run along the sweep when applied with a normal UVW applied material (the default), then just adjust the settings (Offset/Tiles U/V).
