Activity Forums Maxon Cinema 4D Texture rendering differently on separate surfaces
  • Texture rendering differently on separate surfaces
    Posted by Aaron Dewitt on November 9, 2016 at 9:19 pm
    I’m trying to get rid of the home button on an iPhone model. The model was originally a hypernurb that I have made editable. Instead of trying to create a new polygon to fill the hole, I just made a simple plane and put the same texture on it. But, when I go to render, it looks different than the face. I made sure the plane was completely flush with the phone surface. Any ideas?
    Hole
    Plane
    Render
    Brian Jones replied 9 years, 10 months ago 2 Members · 1 Reply
  • Brian Jones
    November 10, 2016 at 4:06 pm
    the phone looks like it’s not likely to be perfectly flat and in any case it’s not sharing the exact same Phong settings (which may not help even if it was)… you probably have to cut out part of the geometry around the button and do a Fill Polygon Hole
