Activity Forums Maxon Cinema 4D Texture moving surface
  • Texture moving surface
    Posted by Andy Kiernan on September 16, 2020 at 4:35 pm
    Hello,
    I am trying to achieve an effect whereby a person is ‘revealed’ by liquid ‘filling them up’.
    My workflow so far is to model a mesh for the person, matchmove it, and then use Xparticles for a liquid sim inside.
    What I’m struggling with is needing to have the surface of the liquid, that is the top bit, a different colour/texture than the sides (the footage, mapped).
    I’m currently using triplaner mapping to achieve this but it’s not perfect so I’m wondering if anyone knows a way to texture just the surface or to output a matte from the triplaner?
    I hope this makes sense, It’s baking my noodle somewhat.
    Thank you
    Andy Kiernan replied 5 years, 12 months ago 2 Members · 2 Replies
  • Michael Szalapski
    September 22, 2020 at 8:06 pm
    Fields might be your answer. You could do a linear field with a bit of falloff mixed with a bit of noise for randomness and just animate it moving up roughly following the fluid sim. Unless you need it to be really, supremely accurate for some reason.
  • Andy Kiernan
    September 28, 2020 at 8:25 pm
    Thank you for that, its a great shout. I do need to keep it fairly accurate so it gives the impression that the ‘liquid’ is almost painting on the actor’s texture as it moves up. But I am going to try and fake a liquid sim with fields and whatnot, so then able to use your solution and still be fairly accurate. I’ve no idea if I can actually do it mind!
    Apologies for not responding I got pulled onto something far less interesting.
