Activity Forums Maxon Cinema 4D Texture mapping these palm trees?
  • Texture mapping these palm trees?
    Posted by Tarn Mount on November 19, 2017 at 1:06 pm
    I downloaded this model of palm trees and it came with all the various images and textures. But in my ignorance (think noob) I have no idea how to texture map them so they look like the rendered picture. Does anyone know how to make these work?
    I have attached a zipped folder of the model and textures that cam with it. I also included a picture of what it’s meant to look like.
    Cheers, Tarn
    Tarn Mount replied 8 years, 9 months ago 2 Members · 3 Replies
  • Brian Jones
    November 19, 2017 at 7:57 pm
    the UV’s look like they are alright so you just have to import with settings that will separate the leaves and stems (or do if after) – if that’s already what you have then it’s just a matter of using the the images in the material channels. What is the problem, separating the objects or where to put the images?
  • Tarn Mount
    November 20, 2017 at 4:42 am
    Hi Brian,
    Thanks for having a look. Basically I have no idea what I’m doing. I don’t know how to seperate the textures or how to import settings (if there are setting attached to it). You’re talking to a new level of noob here ☺
    I’ve just been opening the model and dragging the material onto the object with no idea about any f the rest.
    Cheers, Tarn
  • Tarn Mount
    November 20, 2017 at 8:23 am
    Hey Brian,
    All good – I worked it out with a bit of googling and exoerimentation. That’s for your help!
    Cheers, Tarn
