Activity › Forums › Maxon Cinema 4D › texture help
  • texture help
    Posted by John Harcus on January 22, 2009 at 12:05 am
    I’m trying to map a movie onto this and not getting the result I want.
    What I want is crawling text that wraps around the right angles.
    Here is what I get:
    Image Hosted by ImageShack.us
    By jharcus
    Seems each plane gets the texture mapped to it.
    Can someone point me in the right direction.
    Much appreciated. J
    Adam Trachtenberg replied 17 years, 8 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    January 23, 2009 at 1:05 am
    Looks like you’re using flat mapping? How is the geometry formed? If it was done with sweep nurbs it should map correctly with UVW mapping. Otherwise you’ll have to adjust the the UVs by hand.
