Activity › Forums › Adobe After Effects Expressions › Texts in two line
Texts in two line
Posted by Arun Longjam on June 28, 2023 at 5:57 pmHi all,
I have a text layer. I want my text start a new line/paragraph automatically after reaching a certain width and start shrinking to show all the texts in two lines. And also I want to adjust the leading of the font. Thanks.
Arun Longjam replied 3 years, 2 months ago 2 Members · 6 Replies -
Filip Vandueren
June 29, 2023 at 5:21 pmHello Arun,
I would use a textbox to automatically limit the horizontal length of the lines, and have a hidden textlayer that tries different fontsizes untill it finds thethreshold of where it becomes a three line text.
Like this:
– make a text-box that has the horizontal size that you want to wrap at, but make it plenty tall so it fits at least 3 lines.
– give the sourceText this expression:
maxFontSize=100;
fs = maxFontSize - timeToFrames(time);
style.setFontSize(fs);
Starting from 0, it will try all integer fontsize starting from your desired maximum/default fontsize.
– give this text-layer a slider control effect, I renamed it to “optimal FontSize” and give it this expression:
posterizeTime(0); maxFontSize=100;
function estimateLines(l,t) {
st = l.text.sourceText.getStyleAt(1,t);
ld = st.autoLeading ? st.fontSize*1.2 : st.leading;
return Math.ceil(l.sourceRectAtTime(t).height/ld);
for (f=0; f<maxFontSize; f++) {
t=framesToTime(f);
if (estimateLines(thisLayer, t)<=2) break
text.sourceText.getStyleAt(1,t).fontSize;(alternatively this could be done witha binary search algoritmh instead of a frame by frame scan)
The resulting fontSize is the first one fits in exactly 2 lines.
You can hide the current layer, and use the calculation in a second text-layer like this:
The second Textlayer should also be a textbox with the desired wrapping width and this expression for sourceText:
posterizeTime(0);
txt = thisComp.layer("input txt").text.sourceText;
st = thisComp.layer("input txt").text.sourceText.style;
st
.setFontSize(thisComp.layer("input txt").effect("optimal FontSize")("Slider").value)
.setAutoLeading(false)
.setLeading(effect("leading")("Slider").value)
.setText(txt);as you see, it now references the contents of the original text, the optimal fontsize, and a new effects slider where you can dial in the desired leading
Arun Longjam
July 3, 2023 at 6:27 am -
Filip Vandueren
July 3, 2023 at 9:54 amHi Arun,
looks like your File -> Project Settings -> Expressions -> Engine is set to “Legacy Extendscript” (it needs to be Javascript)
or, if you don’t see that setting, you are in a version of After Effects that doesn’t support font styles via expressions.
Arun Longjam
July 7, 2023 at 7:05 pmHi Filip, Your first script does shrinking text overtime and second script does manually slider control. I want my text shrink/fit automatically in a box in two lines from frame 0 and will export as a mogrt file. thanks
Filip Vandueren
July 7, 2023 at 9:23 pmHi Arun,
That is correct, the only way I know to calculate the best fontsize for a wrapping textbox is to try all of them and then choose the first one that fits less than 3 lines.
So the first layer (shrinking) is necessary, but it should be hidden.
The 2nd layer is based on a slider, because if you set it up correctly, the 1st slider contains an expression that looks up the correct font size, and the second slider is what you asked: manual control of the leading.
The first (hidden, shrinking) textlayer’s sourceText should be added to your mogrt, it will give a warning that you are adding a property with an expression, but that is ok.
The second visible textlayer will copy the text and style of the 1st with the correct fontsize and leading.
