Activity Forums Adobe After Effects Text/Logo under water
  • Text/Logo under water
    Posted by Daniel Aguilar on January 5, 2015 at 7:44 pm
    Hi everybody, I’m pretty noob in AE, and now I need to make a video that shows a text with an underwater effect on a solid background.
    I need to create something like this:
    I don’t want the pool appeareance, but a solid background, like this
    I tried the technique of the fractal noise effect on a solid, but I didn’t get what I want.
    I also tried with a water footage in diferent blenging modes, but the results were too bad.
    The better result I’ve gotten is what you can see on the second image, I got it by aplying CC Drizzle effect on a solid, but I need an effect that seems more like moving water (like in the first image).
    I’ll really appreciate any recommendation you could give me to get this effect.
    Sorry if my english is not well
    John Cuevas replied 11 years, 8 months ago 2 Members · 1 Reply
  • John Cuevas
    January 5, 2015 at 8:34 pm
    You want to use Wave World(multiple effects on different layers, then use a transfer mode to blend them together) and Caustics. Here’s an older tutorial that should get you started: Dropping into Caustics
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
