Activity › Forums › Adobe InDesign › Text Wrap Issues
  • Text Wrap Issues
    Posted by Hilary Moore on July 9, 2010 at 3:28 pm
    Hopefully this will be an easy question to answer. I design a magazine and when I copy and paste text from Word into Indesign, I find that the text wraps sooner than it should– leaving space on the right side of the column. I can correct it by putting soft returns in at the end of each paragraph (the lines jump into the correct place) but this seems like a silly thing to have to do. And, when my editor goes into the file to make changes, should he change one of those paragraphs, the spacing gets completely messed up. Anyone have a fix for this issue?
    Hilary Moore replied 16 years, 2 months ago 2 Members · 2 Replies
  • Terry Mikkelsen
    July 20, 2010 at 7:29 pm
    Did you try “paste without formatting”?
    Tech-T Productions
    http://www.technical-t.com
  • Hilary Moore
    July 21, 2010 at 12:28 pm
    Thanks for your suggestion. Yes, I tried that and it didn’t help. I also tried importing the text as an RTF and a few other tricks and nothing is making a difference. Surely someone else has run into the issue. Maybe it’s a CS2 thing?
