Activity Forums VEGAS Pro Text Watermark With Solid Background?
  • Text Watermark With Solid Background?
    Posted by Steve Hardeman on March 27, 2010 at 3:13 pm
    Vegas Pro 9.0
    I have a video that already has a text watermark on it. I need to be able to add a new watermark over the top of it with a solid background, thus allowing the older text watermark to be fully hidden.
    Easy way to do this? I would think so but I played around for a bit and I couldn’t find it.
    Help?
    Thanks.
    John Rofrano replied 16 years, 6 months ago 2 Members · 1 Reply
  • John Rofrano
    March 27, 2010 at 3:42 pm
    I would use the Text Generator and go to the Properties tab and select that background color that you want for the text. Then use the Pan/Crop tool to crop the background to just the area that you want (because it will fill the frame otherwise). Turn off the stretch to fill frame option in Pan/Crop before you crop so that the text doesn’t get resized.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
