Activity › Forums › Apple Final Cut Pro Legacy › Text transition: Fade from left to right?
  • Text transition: Fade from left to right?
    Posted by Paul Boone on May 8, 2010 at 11:25 pm
    I’ve been using a lot of fade ins with my text and I’m trying to fade text in from left to right. I know I can fade in or dissolve in, and can do an edge wipe from left to right but I want the edge wipe to be faded rather than a solid wipe. How do I do this?
    John Fishback replied 16 years, 4 months ago 2 Members · 1 Reply
  • John Fishback
    May 9, 2010 at 4:26 pm
    In the Motion tab keyframe a fade-up using opacity. Then apply the edge wipe. Experiment with applying some feathering to see how that looks. You can probably also do this with a Nest.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
