Activity Forums VEGAS Pro Text Toolbar Issues Unresolved
  • Text Toolbar Issues Unresolved
    Posted by Chris Parker on September 16, 2010 at 3:21 pm
    I’ve already brought this up but I fear I won’t get a response now the thread has slipped down the list. I was advised to return Vegas to its system settings by holding ctrl and shift whilst opening it – the idea being to get back the text tool bar (and other media generations tool bars) after it disappeared (I might have dragged it offscreen, but even changing the resolution won’t work).
    The restoring to defaults method has not worked and I urgently need to find out a way of getting my text toolbar back to finish a project. Can anyone help? Or am I going to have to re-install vegas?
    Stephen Mann replied 16 years ago 5 Members · 8 Replies
  • 8 Replies
  • Steve Rhoden
    September 16, 2010 at 4:27 pm
    Whatever toolbar or tab isn’t visible its quite easy to put
    back in place with a keen eye and patience….I could be more helpful
    if you could post a snapshop of the specific area giving the trouble
    for several reasons.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Project Samples at:
    http://www.youtube.com/hentys
  • Chris Parker
    September 16, 2010 at 5:24 pm
    Screengrabs uploaded. When I place a piece of text on the timeline it normally automatically brings up the toolbar so I can type the text etc. This no longer happens and when I press the button to bring it up (2nd image), nothing appears.
  • Steve Rhoden
    September 16, 2010 at 5:45 pm
    From what i see the window could be simply hidden behind the preview
    window or some other panel….drag away all the panels, im sure you will see it behind one of them, then you can place them back as you desire.
    Steve Rhoden
    (Cow Leader)
    Project Samples at:
  • Matt Crowley
    September 16, 2010 at 8:20 pm
    You’ve got a window docked (and squashed horizontally) between the Media Generators on the left and the Preview on the right.
    At the top-left of the preview panel is a small X (to close the panel) and a row of dots (aka the docking handle) below that. Now look at the narrow strip between the Preview and Media Generators panels, and drag the row of dots on that narrow strip downwards away from it’s current position and you should see a window pop out – that’s probably your FX/Media Generator controls window.
  • Chris Parker
    September 17, 2010 at 12:19 am
    Cheers for the help. Unfortunately the strip between the preview window and the media generator one is the mixer, which I’d squashed for some reason whilst I was taking the snapshot.
    I’ve dragged all of the windows out of their locations, and I’m still having no luck.
  • Edward Troxel
    September 17, 2010 at 1:03 pm
    Usually when this happens, the “missing” window is actually under Window’s START bar. Set the start bar to auto hide, look under there and move it back to the main area of the screen, and the turn off auto hide. Alternately, change the screen resolution to a higher resolution, move the screen back to the main area, and reset the screen resolution back to where you want it.
    Edward Troxel
    JETDV Scripts
  • Chris Parker
    September 17, 2010 at 1:36 pm
    Cheers for that. It was right there under the task bar. I can’t thank you enough, guys.
  • Stephen Mann
    September 17, 2010 at 4:14 pm
    Now, get a second monitor to spread out your panels. You’ll never want to edit on one screen again.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
