Activity Forums Apple Final Cut Pro Legacy Text Tool crashing FCP 6.0.4
  • Walter Biscardi
    August 27, 2008 at 1:53 am
    [Dean Sensui] “When I diagnosed my problem I manually pulled the fonts and gradually put them back in. It was a crude emulation of what a diagnostic utility used to do back when Mac was run by System 7.”
    I have approx, 1800 fonts installed on this machine. That’s why I use Font Book to manage them. FCP 6.0.3 and OS 10.5.3 worked perfectly with all these fonts. I find it hard to believe the FCP and OS updates corrupted a font or two.
    What I DO see that has happened is suddenly Font Book no longer works on the Octo Core. That’s probably an issue because now the Text Tool is trying to load up 1800 fonts. Normally I only keep about 200 fonts active at any given time. The Boris 3D title tool is handling the fonts just fine, but the Text Tool probably can’t.
    I’m going to see if anything can be done to fix the Font Book first.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Mitch Ives
    August 28, 2008 at 8:27 pm
    [walter biscardi] “Let me know if FontBook is behaving the same on yours too, I’d be curious. “
    Walter, I upgrade the 8-core to 10.5.4 and FCP 6.0.4 so I could test. If I disable a font in FontBook and then restart the machine, it does not show up in the Boris title tool, so it appears that the FontBook is working on our 2.8 8-core……
    Mitch Ives
    Insight Productions Corp.
    mitch@insightproductions.com
  • Walter Biscardi
    August 29, 2008 at 12:12 am
    [Mitch Ives] “Walter, I upgrade the 8-core to 10.5.4 and FCP 6.0.4 so I could test. If I disable a font in FontBook and then restart the machine, it does not show up in the Boris title tool, so it appears that the FontBook is working on our 2.8 8-core…..”
    Thanks, definitely not working here. Might be time to erase and re-install everything again.
    Read my Blog!
Page 2 of 2
