Activity › Forums › Adobe After Effects › Text That Blows Away Like Sand
Ben G unguren
July 2, 2008 at 8:58 pmKyle,
My guess is that you are applying the noise in the same comp that you’re applying shatter.
Make sure the noise effect is PRECOMPED, or just do the following:
1. Make a new composition
2. Add a solid, apply the noise filter
3. NEST that composition into your shatter compThe problem (or fact, if you will) is that Shatter looks at the base layer of your reference layer — it doesn’t care that you applied noise. BUT if you did the noise in a previous [upstream] composition, it doesn’t know anything about what’s going on in the previous comp, just the [noisy] result.
hopefully that helps
ben
