Activity › Forums › Adobe After Effects › Text shadow levels AE – AVID MC7
  • Text shadow levels AE – AVID MC7
    Posted by Fred Matthews on January 17, 2014 at 9:49 pm
    I am exporting some video with a simple text layer that includes a drop shadow…nothing fancy. My issue is that when I import the clip into my Avid the shadow on the text is coming in at “0” on my waveform when I need it at 7.5.
    I can get everything else to 7.5 with the Levels effect but that doesn’t work with my text if there is a shadow. I can easily put a color effect on it within AVID but I would prefer to eliminate the need by fixing my export/import settings.
    Exporting as a Quicktime and importing as 601.
    Fred
    Fred Matthews replied 12 years, 8 months ago 2 Members · 2 Replies
  • John Cuevas
    January 18, 2014 at 2:01 pm
    Import as RGB and it will come in correctly.
    Or, go to your project settings, change the working space to HDTV(REC. 709) 16-235 and check Linearize Working Space and import as 601-701.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Fred Matthews
    January 21, 2014 at 8:56 pm
    How do I change the black levels on the shadows themselves? I have levels on the text but if there is a way to adjust the levels on the shadows I am unaware of that.
    Thanks.
