Activity › Forums › Adobe After Effects › text rendered in AE7 doesn’t look good when importing to premier pro 2.0
  • text rendered in AE7 doesn’t look good when importing to premier pro 2.0
    Posted by Jezreex on July 6, 2006 at 7:01 pm
    I tried to create a simple animation with text using AE 7 with the intention of integrating it with premier pro 2.0. I tried to use the ntsc dv preset for my composition and also ntsc d1 preset. I also rendered using rgb with alpha at full resolution and the output is .AVI no compression. However, when I tried to import the animation in premier pro the text looks shabby and jagged. it is not smooth as in AE 7. I also tried to rendered it in premier pro deinterlaced but still the text doesn’t look good. is there a solution to this problem or what is the correct why to render animation that will be integrated in an NLE software?
    Axel Rogge replied 20 years, 2 months ago 2 Members · 3 Replies
  • Axel Rogge
    July 7, 2006 at 6:20 am
    This sounds like an interlace – problem to me. If you don
  • Jezreex
    July 7, 2006 at 3:07 pm
    AXEL thanks for your respond I know it is an interlacing problem however how do render without interlacing where do I go to do that. about changing the order of fields how do I do that can you show me in detail? sorry for being a pain I am just starting to use AE. I hope you can guide me. thanks a lot in advance.
    jezreex
  • Axel Rogge
    July 7, 2006 at 4:16 pm
    No sweat!
    After you started Movie Making with CTRL-M, the render list opens (next to timeline). If you have AE 7, you must enlarge the window to see the render queue. Beneath every job in the render list you can change four types of settings: Render Settings, Output Module, Protocol and Save as.
    If you found what I
