Activity Forums Apple Final Cut Pro Legacy Text Recognition Plug-In
  • Text Recognition Plug-In
    Posted by Timothy Habrock on April 12, 2010 at 6:03 pm
    Hello,
    Does anyone know of a text/subtitle/title recognition plug-in for Final Cut Pro.
    I need to log the timecode of all text/titles in a project and was hoping to avoid logging each one manually! 🙂
    If there is not a plug-in for FCP, do you know of any other solution, standalone or otherwise, that can recognize text and log the timecodes?
    Thanks.
    Tim
    Michael Gissing replied 16 years, 5 months ago 3 Members · 3 Replies
  • Arnie Schlissel
    April 12, 2010 at 6:49 pm
    If all of the text is on a single track, you could export an EDL for that track.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Timothy Habrock
    April 12, 2010 at 7:28 pm
    Unfortunately, this is not a project in FCP. The source is a final master on tape, we need to log instances of text in program and I was hoping there was a way to do this in FCP, or by other means, that works in sort of the same way as scene detection.
  • Michael Gissing
    April 12, 2010 at 10:45 pm
    Scene detection is relatively easy and useful. I don’t know why anyone would bother trying to write a plugin for FCP that does the immensely difficult job of object and character recognition of a single composite file inside an editing app. Most people use EDLs or XMLs to extract that info from a timeline but a finished master tape?
    In the time it would take to capture the tape, you would probably have half the job done by shuttling through the tape with a pen & paper. If a magic plugin existed, it might take days to analyse the program and then an operator would have to manually check everything anyway.
