Activity › Forums › Adobe After Effects › Text projection
  • Text projection
    Posted by Elcritic on July 19, 2007 at 3:07 pm
    I want to achieve an effect of projecting text into intersecting walls. Is there a way that After Effects recognizes those intersecting solids and continues the projection with the correct deformation?
    Jason Brown replied 19 years, 2 months ago 3 Members · 4 Replies
  • Jason Brown
    July 19, 2007 at 3:18 pm
    My thought is to create a wall with text on it, duplicate it…then place it intersecting with the other wall at the desired point where the text breaks.
    If your looking for the *correct deformation* what I think you are saying is that a wall not at a perpendicular angle to a projector will *stretch* the image…you could achieve this by simply scaling disproportionatelly (sp?) the text size and defocusing it on the wall closest to the camera.
    HTH
    -JB
    -Jason Brown
    Director of Photography
    ideavenue
    “I love the COW!”
  • Elcritic
    July 19, 2007 at 3:37 pm
    Sorry I forgot to mention that the projection would be animated. For example the text would be projected to a wall and slide down to the floor.
  • Roland R. kahlenberg
    July 19, 2007 at 3:45 pm
    As Dave has mentioned, use Light Transmission. Take a look at this tutorial from one of the COW’s bestests – Rick Gerard
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • Jason Brown
    July 19, 2007 at 5:01 pm
    Hey Dave,
    Great suggestion…I always love your workarounds. Good call.
    -JB
