Activity Forums Adobe After Effects text problems
  • text problems
    Posted by David Dibartolo on October 25, 2005 at 1:40 am
    I have problems with moving text not looking crisp, very anti-aliased. Someone had suggested it looks “de-interlaced”, I am not sure what that means. I am also getting alot of artifacting and noise surrunding just the text. the images and solid shapes look great. does anyone have any ideas?
    the text is nested and collapsed in comps a few levels deep, could that be the issue?
    I have build the text through the After Effects text tool, should I try brining in text through Illustrator?
    thanks for the help
    Steve Roberts replied 20 years, 11 months ago 3 Members · 3 Replies
  • Ben G unguren
    October 25, 2005 at 5:14 am
    Select the text layer (or the nested layer with the text) and press command+u. That should anti-alias. And fix the problem. If that was the problem.
  • David Dibartolo
    October 25, 2005 at 1:29 pm
    to be more specific I am getting this problem after I publish to DVD through DVD Studio Pro. Is there a fool proof procedure for making a DVD?
  • Steve Roberts
    October 25, 2005 at 2:07 pm
    The codec for DVD is MPEG-2, and it’s not perfect.
    Are your titles bright red? If so, you should desaturate them before rendering by choosing a desaturated red for the text. Most codecs seem to degrade bright, saturated graphics.
    Steve
