Activity › Forums › Adobe After Effects › Text Problem when viewing on TV
  • Text Problem when viewing on TV
    Posted by Jon Pavli on April 10, 2008 at 8:09 pm
    Hi everyone,
    I have an issue and hope someone can give me a little guidance. I am not sure if it is Afer Effects or Premiere that is causing the problem. I suspect it is AE, so I will start here.
    I have red text that I have rendered out as an avi file. The original comp is pretty basic, the only effect that I have is ‘glow’. Imported it into Premiere Pro 2.0 and burned it onto DVD. The text is scrolling across the screen (TV). As it is moving, you can see horizontal lines TV lines rolling up through the red color as the text moves from left to right across the screen. It is quite ugly. Is there anyway to clean it up.
    I am using AE 7.0 with Windows XP Pro here in the U.S.
    Thanks for helping.
    Cheers, Jon
    Jon Pavli replied 18 years, 5 months ago 58,352 Members · 3 Replies
  • Jon Pavli
    April 10, 2008 at 9:33 pm
    Dave,
    Thank you so much. I am constantly learning from you. I will give your suggestions a try.
    If you don’t mind me asking another question, is there any easier way that changing the levels on each layer one at a time. I have about 20 or so layer with the red text.
    Cheers, Jon
  • Jon Pavli
    April 10, 2008 at 9:36 pm
    I mean to say “than changing…”. Sorry about that.
    Jon
  • Jon Pavli
    April 11, 2008 at 3:42 am
    Dave,
    Your suggestions work. Once again, thanks for the great tips and help on the COW!!!
    Cheers, Jon
