Activity › Forums › Adobe After Effects › Text Problem
Text Problem
Posted by Muslem Arqawi on December 18, 2019 at 7:38 am
I can’t center the text because the bounding box is just around the number.
why is it doing this and is there any way to fix it.
Muslem Arqawi replied 6 years, 9 months ago 3 Members · 4 Replies -
Graham Quince
December 21, 2019 at 11:45 amHard to tell without viewing the comp, but from your screenshot, I’d assume the 1 is it’s own, separate layer. If it isn’t and AE is unable to cope with arabic characters, it might be easier to manually align it.
http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
https://shiveringcactus.wordpress.com/ – FX blog -
Cye Charles
December 21, 2019 at 5:06 pmYou can add a shape layer to the position where you would like to center to… then parent whatever layer (inyour your case your text) to that shape whilst holding down “Shift” on your keyboard. It will snap it into place and then just unparent it and delete that unneeded shape layer. Hope that can helps you.
Muslem Arqawi
December 22, 2019 at 7:21 amNo, it’s on the same layer
it works with the Arabic language just fine but it’s when I add a number or a symbol at first it acts like this
