Activity Forums Adobe After Effects text pixelizes in 3d space
  • text pixelizes in 3d space
    Posted by Joe Mason on August 17, 2005 at 6:23 pm
    Recently I created a comp with several layers, including text, in a 3d environment. Everything looked fine except for the text, which pixelized/tore in the final render. The only way I could get this to change was to use a different color text. (grey instead of saturated blue) Any idea why this happens?
    Joe Mason replied 21 years ago 2 Members · 2 Replies
  • Steve Roberts
    August 18, 2005 at 3:29 pm
    It depends on your codec. Some don’t like saturated colours. To which codec are you rendering?
    Got a screengrab?
    Steve
  • Joe Mason
    August 22, 2005 at 7:23 pm
    It was the DV/DVCPRO NTSC codec, for use in Final Cut Pro. Must have been the case – the only fix was to use a different color. Thanks.
